The nfs-mount
interface allows the mounting and unmounting of Network File System mount points within a snap’s writable areas.
Note: This interface only supports NFSv4. This should not cause problems as earlier versoins are now considerably old and are unlikely to be being used.
Auto-connect : no
Super-privileged : no
Requires snapd version 2.62+.
This interface requires only the addition of nfs-mount
to a snap’s list of plugs
, unlike other mounting interfaces which require additional rules.
Additionally, the userspace binaries required to mount shares are not included in base snaps. They will need to be installed manually from the nfs-common
package.
The following is a simple example snapcraft.yaml
with accompanying mount and unmount scripts for a snap that will mount and unmount an NFS share within $SNAP_COMMON
base: core22
version: '0.1'
summary: Example Snap showing off the new nfs-mount interface.
description: |
This snap provides two commands: nfs-mount and nfs-unmount.
Mount takes a single argument in the form of <hostname>:<nfs-share-name>.
grade: stable
confinement: strict
apps:
nfs-mount:
command: bin/nfs-mount.sh
plugs: [nfs-mount]
nfs-unmount:
command: bin/nfs-unmount.sh
plugs: [nfs-mount]
parts:
scripts:
plugin: dump
source: ./src
organize:
'*': bin/
packages:
plugin: nil
stage-packages: [nfs-common]
The mount script nfs-mount.sh
#!/bin/sh -eux
# If not argument is provided, print help and exit
[ -n "$1" ] || {
printf '%s <hostname>:<nfs-share-path>\n' "$0"
exit 1
# Ensure that the mount point has been created
[ -d "${SNAP_COMMON}/mnt" ] \
|| mkdir -p "${SNAP_COMMON}/mnt"
# Attempt to mount the share
mount.nfs4 "$1" "${SNAP_COMMON}/mnt"
And the unmount script, nfs-unmount.sh
#!/bin/sh -eux
umount "${SNAP_COMMON}/mnt"
The test code for this interface can be found in the snapd repository: https://github.com/snapcore/snapd/blob/master/interfaces/builtin/nfs_mount_test.go
The source code for this interface is in the snapd repository: https://github.com/snapcore/snapd/blob/master/interfaces/builtin/nfs_mount.go
Last updated 1 year, 1 month ago.
